Hey ppls,
I've recently dropped the rb20det gearbox out of my factory manual R32 and fitted up an Rb25DET gearbox.
One measurement I assumed would be ok was the height/position for the rear of the box.
With the r32's std gearbox cross member bolted up the rear of the rb25det gearbox fouls with the floor pan as the 25t box has a slightly different' mounting height.
If any one has their shifter boot off and fiddling around could you please take a measurement of how the very top of the shifter housing (as marked in the attached pic) is positioned relative to the floor pan.
With it all bolted up mine sits 25mm above the floor pan; I can only just get the shifter boot over the shifter but can't shift gears as its too tight. :(
Any held would be greatly appreciated.
Champ.. I'm after the rb20det box height as thats how I wish to setup the rb25 box.
So you measured or was it a bit of a guesstimate? :thumbsup:
Either way I vaguely remember thats how my rb20t box was sitting also.
Looks like I need a 35mm Spacer :S
Pushing my luck a little. :)
If the cars on jack stands.
Any chance you (or any one) can grab a measurement from the gearbox/tailshaft dust shield to the floor pan?
The shield where the tail shaft yoke slides in to the gearbox.
I'm unable to compare the difference between the two box's as I got rid of the 20t box. :(
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
