If it was remapped and still returning poor fuel economy disconnect the o2 sensor and see how it goes for a tank.
If tuned correctly you should see next to no difference in fuel economy with the o2 sensor connected and disconnected.
For what its worth my o2 sensor is currently disabled yet still returning good economy. :worship:
cool, i'll try that when i fill up next... ok now a noob question (puts on flame retardant suit) im not very familiar with RB series motors, having come from toyota 7M's (shudder) and 1J's. how far down the zorst is the O2 sensor on an RB20 DET?
What is with the second hand car market??? will it ever improve? i mean not everyone has houses and the like, where are the disposable incomes that spend money on just buying a car like we all did???? is it the fear of a stolen skyline that are putting people off? Defects.... because they have seemed to slow down lately.... money? I just dont understand....
Anyone???
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
