if tangles happens to wander through here,
been reading through the 'rise and rise of kevin rudd' thread in the wasteland to kill time, and i like the way you think mate. :)
Bosch 023 is the next step up from 040 and can handle roughly 200hp more (~800hp) , and it still fits in-tank ?
That true ?
Is it worth getting this just to be safe (unsure how hard to push the engine at this stage...) ? I saw 1 on ebay for ~$195 delivered. (Says its genuine Bosch). Steer clear of ebay 1s and go get it from a shop ? Anyone using this pump ?
Thanks
Edited by KISIN
Does anyone know who would be best to fix up the trim on my Momo Wheel? it is splitting at the seam, but the condition of the leather is still good, so looking for someone (motor trimmer perhaps?) to essentially glue it back together with the correct adhesives.
Cheers
i have what i thought was a 32 gtr wheel, but appears to be a 33 s1 wheel
had it since january....horn didnt work cos of a different setup to the 31
has a slight worn patch at about the 7 o clock position
if it works for ya steve ya can have it
http://www.drambuieresearch.com/
Hmm bogans and drambuie do they mix lol :cheers:
ROFL i heard you like it but...
can anyone answer this
ORC TSUINPURETOKURATCHISETTO RB26RB20BNR32BCNR33
will that clutch suit a GTS4 push type ??? :w00t:
this is what i want to get
also does anyone know how much meat is " Disk remaining two are 4.07 mm so still usable. "
i had 3hrs sleep today and had to go to observation day thingo with
this place i had an interview with on Monday.
it went quick so it was good ;)
oh my brother bought another Celica :rofl: , it's manual so
i'll be learning manual in that when they get it registered
(hopefully next week)
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
