Cara, KYB Excel G is what you want. Speak to the guys at Car Torque on North Tce Kent Town. I got KYB's for my 33 they are fantastic and shouldnt cost much at all. They should be fine with your king springs
Yeah, at the **old** age of 27, I think my days of hard drinking are over, and I proved that yesterday. Still enjoy a social few but thats about it. Just can't stand writing off the whole next day any more.
cheers lee, how much did u pay for yours???
Cara, from memory it was about $600, but 34 may be different.
I actually got a better price from SA Suspension Centre (ween Rd Pooraka) but got Car Torque to match the price as I liked their service better. See how you go :thumbsup:
After heaps of talk on pod filters and the ASM test which claimed that the 3A Racing filters came out on top...has anyone actually used the 3A filter since then ? How do they seem in quality, are they the dry unit or need oiling etc ? Never got a chance to take a look at 1 in real life but im keen on trying them out ($25 each lol).
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
