This might sound stupid bit can i get a defect for a glovebox that will not open :yes: ? im thinking of making a carbon gauge and boost controler holder that fits inside the glovebox
my glove box has a has a facade that fits inside it, and it holds my water temp gauge, oil temp gauge. and has a spot for my ebc.. there is no room to put anything but a small piece of paper... went thru regency with it in there. it does open, but is essentually useless for anything else.
Changing the glovebox to hold the boosat controller isnt a problem, but having a boost controller is. They will argue that increasing the boost may chjange the emmissions, and hence is illegal (basically any mod that gives you more power could be interperated as changing emissions and hence a breach and defectable)
I know they are illegal and can be seen in the engine bay aswell but for some cops that dont know what they are looking for in the engine bay but know what to look for in the cabin. I thought it would be a good idea to place the controler in the glovebox and maybe have it locked and if i get pulled over ad say iv lost the key lol but can i still get defected for saying the glovebox wont open?
I have tucked mine up infront of the fuse box, you cant see it unless you open the fuse panel.
How often do you use the boost controler? mine is pretty much set and forget (I leave it on low boost, and only open the panel and select high boost on special occasions)
should b fine, similar to what i have, but mine is poxy black plastic :blush: ... im not keen on having boost controller on display, its no longer in there, but thats just me
Talking to a few people I hear regency have installed their emissions tester (though I would prefer external confirmation on this). If this is the case potentially boost controllers and non standard turbos could be considered legal if you could pass the emissions test.
In NSW (where people have public access to such testing centres) tuned cars have gotten through the emissions test, but in SA we don’t have any workshops with the gear to do the proper test.
Whilst it could be done, it would be expensive here in SA.
Edited by 4door_Sleeper
got my PC steering wheel FTMFW !!!!!!!!!
lazy ass post man did not even come to my house to drop off a note that its ready for collection, so it ended up getting sent from my local post office to the general post office in town.. went there to get ti today... (this was delivered from nsw on the 24th dec).
moral of this story... use registered mail with every fkn thing u get from ebay, this seller did not offer it, but even so i should have asked for it.
/rant over
yeah, its in the new gtr discussion forum.
had to happen sooner or later.
::EDIT::
...Looks like the UK
not f**kin likely. last i checked, the symbols on the police bike werent english.
got observation skills?
Edited by scandyflick
how is this for keen !
"In Perú from Huánuco to Tingo Maria, where the road from the Pacific coast across the Andes finds its way towards the Amazon lowlands. This is near the top of the last mountain pass. From there, soapbox rider can enjoy a vertical 1000 meters of gravity assisted ride. As these kids help stranded truck drivers along the road, they're called bomberos (firemen). They transport drinks, food and spare parts to broken trucks."
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
