wow wish i could quit mine!
do it!!!!
nothing like a little peer pressure, I've been getting it on my phone from a few influential people
don't do it unless you have somewhere else to work
have to say i'm getting the "am i doing the right thing?" feeling now
ah what size is it
I think something like a 3inch pipe with a 4-4.5inch tip. havent really mesured yet. all stainless to.
Hope i get it all done tomorrow, wouldnt mind hearing how it is in the tunnels hehe
Hey Pete its ceramic and after 5,000 rpm it sounds like a supercharger whistle so now I'm not boosting @ all and I've taken as much boost out of the manual controller as i can so its basically running factory boost to which i'm not using trying to drive on 0 or neg vacuum
Sounds like you've lost a little bit of the impellar which probably just shot out of the exhaust.
I wouldn't be doing too much driving if I were you because the blades can get fairly unbalanced and shatter now.
OK if the pieces shoot straight out your exhaust.......not OK if a piece gets caught between an exhaust valve and seat.
oh what happens then and when I'm on negative vacuum my understanding is the turbine isn't spinning?? :(
Wouldn't have thought it would stop spinning altogether but as long as your under boost I can't imagine the thing would fly apart.
You would think that the ceramic has gone but you never know, it could also be something else?!
My old 32 was doing this about a day before the rear tubine let go and lodged itself in my cat, as SLED said i really wouldn't wanna drive the car that much cause it sounds like the turbo's close to death
yeah I'm doing barest minimum with 0 or little boost
when mine blew i was in town and had to drive my car to woodcroft to my mates to fix it, was a f__ked drive with no boost trying to get up south road
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
