just driving normal seemed to have pulled a little from fire wall or the bracket twisted maybe cracked wont know fully untill i get to look at it 2morrow has happend to a mate of mine just unlucky i spose not sure if i can weld it or if i have to get another one :banana:
Cronic, its not the actual pedal but rather the pedal box; the box that holds the pedal.
They have crappy little spot welds which pop eventually. If you don't let it get too bad the box is salvageable as it doesn't completely rip apart.
The fix is to simply weld the box up nicely.
kisin this is a couple of pics of the car i was thinking of
come on steve we all know that the signs on the window have no correlation with the actual car :) after all there is the picture somewhere around with the V8 on the s15
I bought a reienforced clutch pedal bracket from JDM CONCEPT for $129.00 delivered after looking at my stock bracket and seeing that it was bent and very weak looking
Most likely similiar to the Nismo item. Its around the same $$
http://www.nengun.com/nismo/clutch-pedal-bracket
lol nick sifnt the V8 wasn't an Autech option
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
