yes but big spacers like that suck ass.
So no.
Would love some VS-XX's or VS-KF's though, but not spending another $3K on wheels at this point in tme LOL.
Besides, the Keto's new shoes are gonna rock everyones jocks :):):bunny:
So no.
yeah, 55mm spacers would be somewhat excessive.
care to share? :P
shutup
its fine
as is my alternator.................stupid bollocksin POS...........................time to look for a Ford i think LOL
buy a toyota.
:ninja:
Yep. Im not happy about the 25mm's I got going up front as it is.
care to share? :)
15 x 8 -4 Superlights in platinum. Will be fitted with a roll and slight flare, also dropping the car an inch in the rear and half an inch in the front, then being repainted in the original toyota off white.
buy a toyota.
Why? So when it breaks down it costs 3 times as much to fix? LOL.
Least with a crummydore you know there's a shitload of spares going around, and they dirt cheap.
Just needs a 5ltr and she'll be right LOL.
f*cking. nice!
least they dont break down 2 days later :)
very true.
and a working electrical system.
Edited by scandyflick
Well, he still pops up every now and then, but without his license he's been missing for a while.
My day is a bit meh, too much work to do so really SHOULDNT be on here, but having CBF with work issues LOL
Oh that's right I remember him telling me now...
Mine is the same, I have to get end of month done but CBF either :laugh:
Plus I am a bit out of it this monday...not sure why either lol
Im covered in Body filler and have primer dust up my nose.
But I have finished guards.
And a quick not to those who dont think you can fit wide, low offset wheels to an aussie delivered R31, you're doing it wrong, and harden up.
That is all.
(BTW Matty, I think your spacers are in tyrepower.... BJ tried to give them to me and I was like "WTF? You're kidding right? Im not running 35mm bolt ons" LOL)
Edited by R31 drift pig
That is all.
weeeeeeeeeee
*goes to get keys, then looks at the fact its 10pm*
will go past tomorrow methinks
operative word being "THINK"..
They weren't sure who's was who's.
Mine wont rock up till friday now.
mine were meant to hav been in last friday lol
begs the question, what hav i got on the front of mine atm?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
