nice as cruizin, youd be cheerin.
I was so cheering all day been looking for a xf ute but come across this on ebay and the owner was champ he bought a new battery for it before i picked it up cost him 120 and he dident charge me and she drives like a new car plus i know the 4.1efi engines like the back of my hand
Yep. Skids. Big ones. And lots of em. And continually be thrashed like a $2 hanson road special.
And when she breaks, RB25DE goes in.
be nice there not that cheap and nasty they have standards lol cant wait to see some of them "skids"
And that falcon is clean as!
25 owns 20, simple as that....:(
driven many different combinations with both motors.
25 has more pro than con in comparison
hey, its no redtop ryan hahahahaha
yes
silvertop owns NICS redtop anyday
i rememeber my massive 79kw on 5psi from that motor
56t gt2871r
10psi at 2400rpm
210rwkw on 8psi with 10.1afr's
Hey Ryan, with 10.1 afr's you should tie a bucket to your zorst and recycle the fuel thats pouring out.
210rwkw could go up another 20 or 30 if you pulled some fuel out. :domokun:
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
