Car will have to be returned to COMPLETLEY stock.
430hp indicates new turbo(s), fuel system, exhaust, FMIC, engine build, Management/ECU etc.... all have to go back to standard.
Compliance - $5K plus getting all the stock shit.
All the freight charges/import taxes/duties etc.
be looking @ $20K - $25K after all that +tyres/Inland transport/rego etc.....
Cheaper and easier to buy one here. :blink:
so how is your car Jess only minor problems i hope
Did a CV joint Thursday night coming home from work :(
So couldn't put on in in time to do the trip..
Took the proton instead but found out the shocks are dead in it...so didnt make it a fun journey 800km on the Highways :D
Only made it to Melbourne...and decided to drive back home :blink:
I will be over in a few weeks for a weekend so will catch up then!!
Wonder if some of your guys would be interested in entering DECA in May at Shepparton??
All that shit still has to be done. IF you can find one for $6-7K (which is going to be a tall order, theey're still 10K there....), still going to be $15K by the time you get it just READY for rego. add in rego/tyres/on roads/inland transport etc and you still nearly on $20K. And you're starting off with a stock car.
Buy one here already modded and ready to rock and save the time/hassle/headf**ks and the 3 month wait. If you buy one from interstate still cheaper than bringing one of your own over....
Edited by R31 drift pig
Sweet! Heard good things about those turbo's on 20's.... f**king hard to get hold of though. I know where there's a complete RB20 kit, but it's $2K or something stupid, So I went with a trust turbo.
You changine injectors/AFM/ECU at all?
Id add a Z32 into the equation and shoot for 220 - 230. Those turbo's are capable of 250...... and reportedly VERY responsive on a 20..... sounds like it's gonna be a stomper setup though.
Im basically running a similar setup with my TD0620G 8cm (Walbro (soon to be 044 and 2.5ltr surge tank)/FMIC/exhaust/DMAX manifold/GTR injectors/Z32 AFM/Boostworx Remap/RB25 box), and shaun tuned a similar setup on a R32, 241kw's on 16 psi, full 16 psi By 4000rpm. Ill be running 1.2/1.3 bar and a 8500rpm limiter.... Hoping for a solid 250.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
