hey wats that double sided tape that ppl use to hold bodykits on?
the strong stuff? and i canget it from bunnings yeah?
i've seen it at car toys before, but you could use zip tie work just the same and probably be chaeper
Are you serious or just messing around???
Im serious if someone has the money. Everything has a price.... and there's more important shit to be done to the car ATM.
If no one has the money, it get's put on and run at low boost until I can afford to upgrade shit. With my missus's car officially out of action, I have to get it on the road ASAP.
You have money.... PM me. :)
As for the ziptie/double sided tape convo, use 2 small tek screws on the ends of the skits inside the wheel arches, and cabletie the front bar on.
As for R32 coilovers.... how much you have to spend? I know of a few sets ATM....
Im going to go die in a corner now. :P
i purchased some from the body shop on Pt Road. A huge role is like 15 bux or something....i used it for my rear pods...works very well, altho my kit is factory Plastic injection moulds...they fit snug as, with alot of fibreglass kits there will probably be a small contact area with the actual body so may be better to use tek screws..
Edited by Ryanrb25
AHAHAHA That was my other option when i was looking at plates for MY maroon 33.....LOL But stuck with the ol RBB 033, close but no cigar!! Now my mate will have those plates when he gets the car!! People may mistake the two cars!!
Haha great minds think alike!
And then there's girls........ Can never have enough of all of the above, but you gotta spend some of one of those to keep the other!! well actually both ;)
And if you want to know exactly how much she costs you then click!
(Possible re-post)
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
