are those pictures before or after you changed it back to standard?
before! it was like that when i brought it! it is now standard looking, std rear bar, s2 spoiler, type m skirts and a r33 gtr front bar! couldn't fit the fmic in the standard bar so i got a gtr copy!
Edited by nos man
thanks luke, you can vote more than once to if your feeling generous ;)
Thanks heaps to people that gave chucked a vote up.
Link on this post too just so this page has it also :glare:
http://realcars.zooweekly.com.au/ViewProfi...x?profileID=469
hehe if i win ill buy everyone a drink :D
Was reading up on WRC.com, and came accross this little extract:
FIA rules say that WRC cars must be based on a standard road car bodyshell. For WRC use it is stripped to the bare metal and the spot-welds that hold it together are replaced by seam welding. All unnecessary brackets and mounting plates are removed to save weight, and a tubular steel roll-cage is welded in. After around 700 hours of work it emerges vastly stronger and stiffer than before. Most WRC cars could support the weight of ten road cars. The FIA requires all WRC engines to have a 34mm restrictor in the air intake, which holds down power output to around 300bhp. The cylinder block and head(s) must be based on those in the standard road car, but the crankshaft, con-rods, pistons, cylinder linings, valves and camshafts can be modified. Typical turbo boost is 4-5 bar - compared with up to 1 bar for an average road car - while anti-lag systems mean the turbocharger delivers maximum boost from tick-over. The result is massive torque - up to around 700Nm - about the same as a Ferrari Enzo.
All I can say is holy poop! 5bar = 70psi!!! Love to see an RB25 hold that LOL
^yeah, thats true. Amazing that the intake restrictor (34mm) restricts them right down to 300HP - would love to see what they could get without the restrictor in place. With those sort of pressures would surely have to be 600HP+?
BTW I just hooked up my new Samsung 22" widescreen SyncMaster 2243 monitor for the PC :D Time to watch some movies :O
I have 22" LCD screens at work and hate this small 17" at home ... so I went out and bought an LCD better than the one I have in my office. :D
:D
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
