Nothing worng with it at all, Just pulled it out to finally find out what I have inside and I actually have a R33 GTR engine in my car :down:
I pulled it out to put a sump baffle in it(as wasn't sure if it had one already) and get it ready for more power...
It looks like it's never done a days work inside, all in awesome condition and looks new still :P
I just wanted to share :blush:
Hey does anyone know a good place to get Sandblasting done, preferably in the NE region
also around how much to expect to be forking out.... I want to get my Rocker cover and Manifold done so I can spray them to match my rims :down:
anyone here know how to replace a wheel bearing on a r32 gtst? would love some help as its the last thinkg i need before regency!
will pay... just cant get a good mechanic to do it anytime soon!
pm me.. car can be left with u for the time!
cheers
hahaha lmfao i pissed my self when i saw this
Yeh i love Superbad. Actually i found out that every1 i talked to, either LOVES it HATES it, no in-betweens.
Also...the first few secs of this always crack me up
http://www.youtube.com/watch?v=xaQFwN3nqk8...feature=related
Edited by KISIN
I absolutely hated Superbad - so much so that I turned off half way through.
Dodgeball rocked my world though :D
Employee of The Month is my new favourite - so classic .... "who is Anal?"
hey have you come across that scene wen they come of the bus and they see mclovin and its like in slow mo and the fat guy is like w t f lol ahahha ? lol i cant seem to find dat scene its funny as lol
yeh i remeber, funny as.
another 1 that also got me, is when they are talking about how they got pissed, and the scene where they throw up all over the fat guy :blink:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
