whats sizes offsets u getting ?
U getting any flares ?
Im getting 16 x 10 -26 (same as in pic) il be paiting the center black or gold so they should look good with some rubber stretched over them and flares to make her look tuff :thumbsup:
will those need spacers ?
And where do u get the flares from ?
lol sorry about all these questions !
I knew as soon as a few people started getting flares, EVERYONE would have them.... thank christ I have a lot more coming for my car.....
And you're complaining about $1.50? I paid $1.69 today.....
Edited by R31 drift pig
no offence dude but looks like your car needs a lot more coming :)
all joking aside though should look tough when its all the one colour ;):thumbsup:
Have a look from page 27 to 34
http://forum.r31skylineclub.com/index.php/topic,51175.0.html
Im getting the flares from the same guy cant remeber the price tho il let you know tomoro
f**king hot :thumbsup: what colour you going and sell me your kit :)
yep thats the price of premium, so $1.50 isn't all that much when u compair it to that, an it'll probably hit $2.00 in the next few months
Its more i haven't driven my car for a while (last time i drove i payed 1.59 in the middle of nowhere)
yeah, price of petty is one of the reasons i wont be doing the full charity cruise this friday, got better things for the money to go to, and ive already poured a decent amount of cash into my car this week.
f**king hot :P what colour you going and sell me your kit :(
oh dude, if u could PM the details, that would be great ! (from who and price)
r31 drift pig, where did u get urs ?
Hey Dave how much does it cost you to fill the Celsior up?? And how many clicks do you get to a tank?? Just wanna compare the two, as i've always loved the LS400/Celsior, was going to buy a LS400 about 5 years ago, but never went thru with it!! And then the Aristo came to Australia and that changed my mind on what to get!!
Flares are from AJPS as well. Same as declans car.
And Whats wrong with bolt on "fake" flares? Least I have wheels that require them. :P
I had all metal flares on there when I had my 18 x 10 +5's......
Hit up a photo of your wheels mate....
they look fine ahhaha!
just posting a thing i did on photoshop for you r31dftpig
becuz im bored
what about orange ??
what about blue ??
note car will look betta in real life with *real* paint!
****AND ALSO YOU HAVE NO MIRRORSLOL!!!!!!!
Edited by Pepsinator
And Whats wrong with bolt on "fake" flares? Least I have wheels that require them. :whistling:
being my daily thrasher, my parents also take the 31 for a spin sumtimes...and they managed to dent in the left rear quarter (right at the actual "flare bit")...so i might see how much it will be to get a crash shop to make sum metal ones (bigger of course)...
Edited by KISIN
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
