Im going to have to pass steve.... Meant to get back to you about it actually but completley slipped my mind. The 20V is an absolute nightmare to put in, fabricating parts(alt. brackets, modding pulleys, custom thermostat housing)) and blocking off ports etc, custom manifold or IDA trumpets to clear master cyl, etc.... Price was awesome but all the cash afterwards simply isnt worth it on a $1K corolla. If it was a sprinter, then yeah sure... :D
Pepsinator..... Can you do a photoshop in red and one in silver for me? I have a few ideas on what colour Im going to paint it. I have mirrors, just need to make bases for them.
Kisin.... It wont be cheap. Thats all double metal under there.... Mine was simply a massive Vice grip pull, then dollyed flat, and bogged over.
Edited by R31 drift pig
Getting painted as soon as I get my new bonnet/bootlid, and finish mounting the guards.
Colour will remain a secret.
yeah.... also considered S15 pewter, Audi Gunmetal, BMW gunmetal, New VE commodore gunmetal.... If I look at another colour chart Im going to lose it LOL
lol
^^^^ guess its not really a seceret anymore.
seems like your sliding towards the dark silvers, gunbarrel gray's :D
no matter what colour it will look awesome but its a matter of the perfect colour to set it off!
on another note i have blood coming out my right ear.... think im off to the doctors tomorrow
oh dude, if u could PM the details, that would be great ! (from who and price)
Flares are $180 a pair and are made very nice
http://www.ajps.com.au/index.asp
Bloody good work shop i walk in and there was 2 drift ke70s and a ae86 :D They do fab,engine change anythink to do with the old toyota's and the owner Dave is a top bloke
sweet thanks heaps.
lol
Not even close.... Been almost through the entire colour spectrum LOL...
Let's just say the colour is up the other end of the scale....
LOL... Reflective safety tape.
True, it would look good baby vomit green. But, was just saying that Id looked at a lot of "gunmetal" colours...... and I wont be going a darker colour like that. Although Mercedes "Diamond Black" would be rather pimp.....
Im going to have to pass steve.... Meant to get back to you about it actually but completley slipped my mind. The 20V is an absolute nightmare to put in, fabricating parts(alt. brackets, modding pulleys, custom thermostat housing)) and blocking off ports etc, custom manifold or IDA trumpets to clear master cyl, etc.... Price was awesome but all the cash afterwards simply isnt worth it on a $1K corolla. If it was a sprinter, then yeah sure... :banana:
yey thats fine but im at my dadz place and i dont have the photoshop file and well my dad hasnt got photoshop that makes it even shitter
so i be able to do it for ya in 1 week or so (you might get the paint done by then you never know)
metallic gray would look sweet on there or a like
that would look PIMP!!
Hey Dave how much does it cost you to fill the Celsior up?? And how many clicks do you get to a tank?? Just wanna compare the two, as i've always loved the LS400/Celsior, was going to buy a LS400 about 5 years ago, but never went thru with it!! And then the Aristo came to Australia and that changed my mind on what to get!!
tends to cost about $90 a week, on a cheap day of course. depending on how i drive, ill get anywhere between 500 and 650 km. so it isnt that bad on the juice really, hows the aristo stack up?
ill throw the keys at ya for a spin after ajd. :banana:
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
