whilst it looks very nice and all you might want to change it before i report it and i would have to report you for it based purely on file size the file being 1.2mb im actually surprised SAU let you host it as you av
edit
ill try some more but here is a acceptable edit of it
Is that better boss? ;)
yeah man .. we have to spare a though for those not on
1) destop's with high bandwith
2) people browsing on mobile phones ala me
3) people browsing from ISDN @ work ala me
if you want i can see if there's anything else you might like in that compilation of corners but i have to go out in 10 mins so will have to be later
Yeah, well i thought SAU would have automatically rejected it if it was too big, so i went with it. This edit is good, shows some mean angle! thanks ;)
I was reading on transport SA that on passenger vehicles manufactured after mid 70's ish, no modifications are allowed to injectors, catalytic converter etc.
does this mean if i get a high flow cat, that its a modification, therefore illegal??
just get a gtr cat.
flows better then most hiflows, and its a factory nissan item, easy.
and just for arguments sake, your car is fitted with wheels that would no doubt change the track, a turbo timer, and coilovers that are probably still adjustable.
legality of those items?
Edited by scandyflick
just get a gtr cat.
Yeah but i was just asking. I know my wheels, turbo timer and coils are illegal, but wasn't so sure about cat.
fair enough.
if youre really hung up on the legality thing, speak to someone at vehicle standards in regards to what cats are legal and which ones arent, gtr cat should be fine though, being an oem nissan part, should be able to pick em up pretty cheap at any workshop that complies gtr's.
basically anything modfied from standard is illegal
so
nice fluffy lambs wool seat covers illegal
nice fully dice hanging of mirror for the extra 10kw illegal
we all know stickers add kw so there illegal
:O shall i go on :)
so
:O shall i go on :)
Do you know any places that sell genuine HKS dice? and who can fit them for me?
Really looking at getting some more grunt.
Not so hung up, just quoted one with Just Jap and queried the legality, and they said they haven't had any problems with them. Might look into a gtr one, thanks for the tip.
What i thought Dave was saying is that why would you worry about the legality of your cat when there a visible defects on your car as it is, and when you get sent to Regency you will need to change everything anyways. When driving these sorts of cars there is always going to be a defect, Or your car would be stock as a rock!!
I say dont worry about your mods legality, within reason, ie not putting 22s on it!!
Where can i get .22's mounted to the roof thats sounds like a good mod :cheers:
Good point Darren, but I wonder if removal of a Cat is also subject to a large fine on top of a defect.....someone on here may know.
Apparently it is, but nobody has been done for it, not even drift guys that drive on the road with straight thru pipes, My 33 had only straight thru pipes to a JunBL muffler, NO cat, sounded killa!!
Ive always heard "rumours" about there being a quite large EPA fine
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
