whilst it looks very nice and all you might want to change it before i report it and i would have to report you for it based purely on file size the file being 1.2mb im actually surprised SAU let you host it as you av
edit
ill try some more but here is a acceptable edit of it
Is that better boss? ;)
yeah man .. we have to spare a though for those not on
1) destop's with high bandwith
2) people browsing on mobile phones ala me
3) people browsing from ISDN @ work ala me
if you want i can see if there's anything else you might like in that compilation of corners but i have to go out in 10 mins so will have to be later
Yeah, well i thought SAU would have automatically rejected it if it was too big, so i went with it. This edit is good, shows some mean angle! thanks ;)
I was reading on transport SA that on passenger vehicles manufactured after mid 70's ish, no modifications are allowed to injectors, catalytic converter etc.
does this mean if i get a high flow cat, that its a modification, therefore illegal??
just get a gtr cat.
flows better then most hiflows, and its a factory nissan item, easy.
and just for arguments sake, your car is fitted with wheels that would no doubt change the track, a turbo timer, and coilovers that are probably still adjustable.
legality of those items?
Edited by scandyflick
just get a gtr cat.
Yeah but i was just asking. I know my wheels, turbo timer and coils are illegal, but wasn't so sure about cat.
fair enough.
if youre really hung up on the legality thing, speak to someone at vehicle standards in regards to what cats are legal and which ones arent, gtr cat should be fine though, being an oem nissan part, should be able to pick em up pretty cheap at any workshop that complies gtr's.
basically anything modfied from standard is illegal
so
nice fluffy lambs wool seat covers illegal
nice fully dice hanging of mirror for the extra 10kw illegal
we all know stickers add kw so there illegal
:O shall i go on :)
so
:O shall i go on :)
Do you know any places that sell genuine HKS dice? and who can fit them for me?
Really looking at getting some more grunt.
Not so hung up, just quoted one with Just Jap and queried the legality, and they said they haven't had any problems with them. Might look into a gtr one, thanks for the tip.
What i thought Dave was saying is that why would you worry about the legality of your cat when there a visible defects on your car as it is, and when you get sent to Regency you will need to change everything anyways. When driving these sorts of cars there is always going to be a defect, Or your car would be stock as a rock!!
I say dont worry about your mods legality, within reason, ie not putting 22s on it!!
Where can i get .22's mounted to the roof thats sounds like a good mod :cheers:
Good point Darren, but I wonder if removal of a Cat is also subject to a large fine on top of a defect.....someone on here may know.
Apparently it is, but nobody has been done for it, not even drift guys that drive on the road with straight thru pipes, My 33 had only straight thru pipes to a JunBL muffler, NO cat, sounded killa!!
Ive always heard "rumours" about there being a quite large EPA fine
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
