double demerits is an eastern states thing it was never officially brought in to SA just trialed it a few years back, they're talking bout bringing it in tho...
They used double demerits in SA over the Easter weekend
I just picked these up from ebay :down:
$375
$375
$66
Its put a hole in my wallet but i couldnt stop bidding lol
You.
f**king.
Suck.
Just checking you are aware... those taillights are missing the centre garnish, and those GT badges are the non-turbo ones.
I want those projectors though!
Ya the garnish is gana be a flamin mongrel to find but i was pretty happy at the prices :down: i was also aware of the GT badges comming from the NA but it looks alot better and diff from the stock item
Were you bidding on the frount lights?
I just picked these up from ebay :P
$375
$375
$66
be aware you'll be devo if ya stove those lights LOL
they aint coupe lights either - theyre passage lights (as they have the chrome trims and are a grey colour)
garnish will be a bitch to find too
Im gana paint the rear lights black maybe with some night shade paint to blend in with the colour of the car(white and black) Im hoping i can use the stock garnish for now till i find one to suit the rear lights.
Im half way into cutting and shutting a volvo frount lip, filling in the frount 3 gaps and adding some to the center so it fits perfect. Is there any place in Australia that can do side skirts and rear bar??
i guess i was wrong...oh well u learn some thing new every day... now to correct my mate that told me...
Nah thats cool, I don't think they had double demerits over the Anzac weekend though so maybe its only an Easter and Christmas thing at this stage.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
