Flick - Do you have an RCD (Safety Switch) on your house? If all the power went off when you got the shock I would say you do, otherwise get one installed ASAP! And if you got the full 240V (iron may be rated to 260V, but Australian system is 240V), then yes you would have got the cramps as 240V contracts your muscles, meaning you wont let go of whatever is shocking you.. its actually the most un-safe voltage in the world :P
Higher voltages throw you off, lower voltages dont contract your muscles... stupid Brits and their 240V system!! LOL
(Note - Qualified Sparky here, cash jobs on weekends :( )
yeah we got a safety switch. Handy thing that..
Didnt get cramps or such, just scared the crap out of me more than anything, was quite a loud zap. Heart was probly racing cos i got so freaked out lol.
Such a girl tho... wasnt worried bout the fact i just zapped myself.. was more upset i couldnt straighten my hair lol
hahahahahahaahahaha.
how did ya manage to zap urself though??
i cant figure it out,
my uncle has an electric fence though around his 1 acre dog compound in the country and he has 2 alaskan malamutes and one day one of em was leaning on the fence and not getting zapped and i was thinking sweet it must be off.
go to climb through it and yeh dumbest thing i have ever done.
my hair was sticking up for about an hour or so afterwards. was best adrenilin rush ive ever had lol
Yeah me too Luke, was gonna buy a 044 and do an intank setup but I like the ease of the Nismo. I know it costs more but hey...
that's why i went nismo! 044/040 is still a fairly easy install in a 33.
Quick Q: would a 910 be just as good as the 044?
910 and a 040 are pretty much the same thing with a different fitting i think, an 044 is an external and bigger which isnt necessary for anything below 300rwkw
I am thinking of getting bosch 044 pump but dont know how to install it....might require ur help if your willing to
040 is designed to be intank, 044 is designed to be external, some people put the 044 inside the tank but dont realise the o rings etc aren't meant to be submerged inside the tank. 040 is the largest intake you can get and will supply more than enough fuel for alot of people.
taken from sliding performance
Nismo In Tank Direct Replacement Fuel Pumps
R32 GTR Model Number : 17042-RR581, $499 Delivered
R33 GTR Model Number : 17042-RR596, $499 Delivered
R34 GTR Model Number : 17042-RRR46, $499 Delivered
R32 GTST Model Number : 17042-RRS31, $429 Delivered
R33 GTST Model Number : 17042-RRS41, $429 Delivered
R34 GTT Model Number : 17042-RRS51, $429 Delivered
S13 Silvia Model Number : 17042-RRS31, $429 Delivered
S13 180SX Model Number : 17042-RRS31, $429 Delivered
S14 Silvia Model Number : 17042-RRS41, $429 Delivered
S15 Silvia Model Number : 17042-RRS51, $429 Delivered
Price and delivery from Australia All fuel pumps delivered in 2-4 Days
GTR a bit more expensive heslo i see
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
