my deductions are it was Dave :thumbsup:
Nice car man it's good to see you joined up :) so when does the SAU discount for petrol start lol That 20bucks of fuel i got today didnt get me far
Hey welcome, do u know who recommended SAU to u? Car looks good, love the rims :)
Hey welcome, do u know who recommended SAU to u? Car looks good, love the rims :bomb_ie:
No idea haha was biggish.. had a nismo hat.. was driving some older ford falcon but says he has a show R33.
hey dude, i live about 2 min walk from ur work :stupid:
naice. :D
hey champ ive seen you a few times around. The other night at the new port rd BP! i was in my corolla the next pump over. dont worry i wont tell rob about you getting other fuel lol! :mage: if i see ya around again ill say hi!
welcome!
Yeah, I rather quality petrol in mine thanks. Our Premium is just mobil shit I think. Ah yeah Maroon R32, Red RX-7 and your little rolla. I remember. That cop was so f**king suss just driving up and down :(
naice. :D
yea no shit, yea dont worry about the dude in the 32, he's a bit of a twat, does the stupidest things to get attention.
very nice car champ.
^Matt: Should have gone full Bull Bar with Amplimesh WITH the spotties :)
Oh, and stainless steel side skirts, THEN you'd be B&S Spec :)
got told by one 4wd place that id need to get a bull bar, or at minimum a nudge bar to fit spotties
Nudge bar wouldnt suit even the standard bumper without cutting (f**k that) - and they wanted 600 bucks for that
Full bull bar woulda been 1500 bucks
so nah, happy to keep my kit and be less B&S (still goin to hav the UHF installed with a conservative antenna)
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
