Last time I heard a squeak under the hood, in my previous car, I thought something was up thought I'd get it checked later when I can get around to it then BAM no power steering! $500 later for a replacement pump fitted....
website for nismo products, tried nismo.com.au.. Would that be it? comes up saying unique autosports.. I'll have a look around i guess..
Edit: Yeh, thats pretty much it ;)
Also the sound from my car comes from the right side of the car, above the wheel? any ideas lol
haha looks good matty u do much country driving?? they will certainly pay themselves off quickly on country roads!! :)
nicely mounted too
probably will be in the future...........hence why i got them. Got to aim them down (as i stood about 3 metres away, the main lights were hittin my knees and the spotties were aimed fair at my head).
those "light bars" are the best investment ya can make, bolts in place of the numberplate......well i tek screwed thru the bar into the reo just in case hahahaha
Looks good :) im thinking of getting a xf ute now, my ford got hit on the side today by a 4x4 with a big f**k me bull bar and spent 5hrs at flinders :bunny: the damage didnt look that bad but i got bad whiplash and spent all my time with a neck brace on. The guy that hade hit me was in a customers car and worked across the road where he hit me on Raglin ave, pulling out of castle plaza car park and didnt see me :P Iv got one witness(castle plaza security) but the flamin mongrel of it all is i hade to pay for the towing of my car to the towyard then to my place $296 and wait up to 3 months for payout its only a xf but it was so clean and my daily plus i spent $400 getting all my stereo put in.
Il post some pics when i feel better and not druged up lol
I think either too many ringies or not enough ringies caused the head to go on the corolla this week, getting the head redone, pistons looks like f*kn brand new!!! very surprised. head will be back on tomorrow and will have some furious 4k action again in no time. It's been good driving the skyline again for a few days tho....reminds me why i still got it.
Hey does anyone know an autoshop that opens on Saturdays, and i can get my rear brake pads changed?
ive rang like 20 places and no one opens on Saturdays...
seaton service centre on tapleys hill rd seaton ask for george and tell him i sent you and he should look after you 8347 3855 he has been a mate for years :D
I heard on the radio the other day... Apparently we are turning in to a bunch of metrosexual pansies as a high percentage of males know very little to nothing about their cars nor do they perform any work on them.
There was a few other things.. Owning a pink shirt was one of them.
So Aussy males are apparently becoming in touch with their feminine side. :S
My self I'm quite the opposite; old school line of thought. :D
So buy some cheap super cheap knuckle busting tools and do it yourself. :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
