i need to get a clutch for my 5speed thats going into the 31 (rb30e clutch)
which 1 and where shoud i get it from ? Read on the 31sky.club at my options and the xtreme HD sounds like the go, being only 25% stiffer over the standard (idem no. KNI24001DHD). How much am i looking at ?
Also do i need a new flywheel or can i use my current 1 thats in with the auto (obviously get it machined)???
thanks
auto uses a flex plate. rb20/25/30 flyhweel all fit.
go to the traders section and ask one of the traders for an rb30e clutch....simple, they'll tell you a proper price.
oh and btw, i wrote the FAQ manual conversion tutorial on the R31 skyline club so any questions dont hesitate.
Edited by Ryanrb25
R34 owners, for your information. This is what happens when you put white L.E.D's in your dash cluster:
But i like it. matches my head unit.
That looks good....but i still prefer the stock white back lights....
Mt Gambier is a beautiful place...
Thanks, found ur post on the 31 club :worship:
:thumbsup:
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
