yeah, the guy my mate is gettin the sus/axles/brakes thru just needs a stud pattern. 5x114.3 gives us the most flexibility (ford, nissan, toyota, mazda, etc).
also will be in contact regardin them stockies :happy:
i hate cars sometimes!
Car is in getting about $1000 worth of work done to her :happy: Im carless until at least wednesday if not longer :D
All new hoses.. thermostat.. cooling system flushed and new coolant, amongst other things.
flick, the hose that gave out on you sounds like the one i had give out a couple of times. cost me about 600 bucks over both times to just have them replaced. woulda lost coolant without knowing it? not until it decided to boil over?
well temp never really changed at all. I didnt have a clue anything was wrong until i got to work and saw the coolant pissing out everythere and steaming! The hose was pretty much split in 2 when i got to the mechanics.
Decided to replace a few other hoses along with it, cos theyre sure to go very soon too
:D i used to work for Olympic Trailers :) making 6x4 5x8 custom and horse float side's and tail gates
in a day from nothing to complete chassis i used to make 2x 6x4 that's cut and bend all my own materials
oh, and a small note
the process is started, my trailer is about to be started :P. Once its built, my mate has said he will be happy to build more (and to your specs). Designs are ADR approved, so will be easy to get passed through a regency inspection to gain registration as well
i'll have my trailer by the time shepparton comes round (give or take a week or two prior to having to go)
I would't mind having a look at that when its finished Matty, as i use to build custom made trailers for 5 years, oh and you dont need to take it to regency to get rego, just need to take it to a registerd trailer manufacture for a quick visual inspection to get it rego'd
hears a pic of one of my old creations, full box chassis, full tilt, winch, side mounted spare wheel, hide away alloy ramps, led lights, 2 pack paint. :bunny:
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
