bah. as if my partner wins something at Kadina Show and Shine and i dont hahahaha.
well done tho on winning Best 4 Cylinder with the WRX, Lex im proud of ya for winning your first trophy. :ninja:
just remember i have 10. YOU have 1.
:blink:
well just got my car back from jeff...
pulled 189.9rwkw on 14psi....
afm meter was maxing out?????? green label?
ok i have a gtr power fc modded for gtst.. now jeff thinks coz the gtr runs 2 afm this may be the reason mine is maxing out?? would this be the case?
coz i thought i would hit atleast 200 with my setup?
also my clutch is sooooooo hard to drive with! stalled it 8 times on way home!!
oh i wanna cry!
The RB26 AFM's are rated less than the 25's I know that for certain, this is probably your issue... question though, is you AFM an RB26 one or 25? If you are using a modded 26 PFC with a 25AFM you shouldn't be having any problems
EDIT: Just saw you have a 32, no idea where the RB20 AFM's fall in the scheme of things, would think the 26 has a greater reading range however
Edited by heslo
STEVE!!! its not funny! im about to throw something!
thats wat i thought! well im gonna ditch my pfc and get a remap! i think the PFC is holding me back??? joel i know u wanna help hahaha
oh spewing so bad! and my clutch made it worse hahaha
damn wed!
jeff said he thinks the green label is having trouble working with the gtr pfc due to a rb26 running two afm! he said i should get a z32 and i agree but im just trying to c y i would be maxing out at 190???
isnt that strange??
and yes i will toughen up hahaha its wat happens when u have a slipping clutch for 6months and get used to being able to ride it hahah
isnt that strange??
I would assume the green one is a RB20 AFM??
I can understand why the 26 PFC would need 2 AFM readings as its twin turbs, but i dont see any reason why they cant wire it up to 1 AFM and have the same reading for both on the PFC, Im no mechanic or auto elec........
hahaha i lol'ed
give it 2 days of driving with new clutch and you wont look back
GTR afms are brown but i think there pretty much the same as the green ones just different wiring
go here for a nights worth of READING
of Luke of you do think of getting the R34 MFD this will be handy for you >>HERE<<
here is a AFM chart too :merli:>>Here<<
:blink: In other words... toughen up princess, right Steve? :ninja:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
