you dont have to bed them in?
Woo hoo, just fitted my Ferodo DS2500's that came in the other day, awesome pads and highly recommend them! When they bite, they bite!
Brendan that ebay cat is US spec cops here will look @ it and think its a hot dog or some shit better off with that race spec cat at least it looks like a cat
but all the best with it :banana:
I followed the initial bed in instructions that they included... but yes, you are correct, I'm still taking it easy for the first few 100 or so kays. Still pedal feel even under normal breaking conditions is sooo much better than my previous pads (got no idea what they were however)
just do what i did, put my new pads in, drove up the street to beggin bedding them in then slam on your brakes to miss a toddler chasing a cat!
yep, my brakes squel and feel like shit! thanks kid.
lol maybe i should save for new rotors too :banana: i think thats on the cards anyways
anyway im off to bed pretty tired 5:30 up 12pm bed kills you by friday
don't buy new ones, just measure and if thick enough, machine them
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
