yay.....................the ute rattles again
this time i wasnt doing anything dumb...............................just driving home minding my own business
really am ever so slightly f**ked off about it................its what some would call "bad timing"
Edited by Matty 31
D_Stirls, Nice find..
When I removed my bushes I did the same except used a drill bit popped the middle then used a hack saw to cut the outer shell. Once the shell was cut it popped out without drama.
I then used a piece of exhaust pipe and smacked the new Noltec bush in.
they sell r33 for like 280 each rotor there!
My brother (GROWLY Custom Machining) will do basic slotting (RDA/DBA straight slot design or curved slots) for around the $40 mark so remember this when you by new rotors, it might be cheaper to get plain rotors and get them slotted. He will do them cheaper again if you get a whole set done.
This is my rotors he did, something like this would be $55.
Edited by D_Stirls
hmmmm, thats very handy! id say standard rotors would be cheaper than slotted right?
and 55 per corner? = 200 atleast for slotting.......i might work out dearer??? sorry, just thinking out loud here....
does this help :)
oohhh, where can i get a 33 gtr placard in case i get pulled over for my 19s?
as nos man pointed out R33 are dearer that price of $129 ea is for falcadoore
i see supercheap sells DBA slotted rotors, 129 ea.....would they stock them for a 33?
Matt the owner of Growly Custom Machining told me take all the prices too him and he will make sure it doesnt work out dearer how much farer can that be
Matt is a top bloke and is here for the community whislt earning a honest living doing what he loves
BTW Matt re drilled my GTSt rotors to suit 4 stud while i waited for my conversion :)
If you look at that picture those rotor have been drilled to 4 stud as they are fitted on my 180sx.
The $55 was for my design which involves more machine time that the standard sots and hence are more expensive. like i said before the basic slots are around $40 and cheaper when you do all 4.
He'll slot any rotor provided they are thicker than the minimum thickness.
Edited by D_Stirls
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
