hehe, you wanna know how i pissed my ex off???
i posted her little buzzy friend to her house, addressed to her dad, with a photo enclosed.....
see, i was smart at some stage...
Oh Craig, that is some of man's best work right there. How bad was the picture, and can you post it up. :)
how do i find out if my timing belt has already been replaced??
i have owned it since 116 k, and my mate who had it before me bought it at 109k..so he doesnt even know if it was done...
i donrt really wanna spend the money on a new one if its only 17 thousand ks old!
i could spend it somethin else, like new brakes....
+1 on above comment
For rb20 and rb25 timing belts please contact me, I have done countless amounts on both motors, Did mine recently even tho its only done 80k.... lol and yes i'd change water pump at the same time! genuine parts aswell.
adrian, scott got those lock bars yet?
Edited by Ryanrb25
i can get trade discount through nisscare...Belt around 70 bux, generic Pump about 50 bux, genuine pump is around 140-160. My labour dunno, but not 300+ like everyone else. plus coolant about 10 bux, gasket glue ill supply lol
PLUS, ill show ya how to do it while talking some shit at the same time. :)
Edited by Ryanrb25
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
