Here ya go, this is what happend at Mallala.
Yeah. That crack would have formed on the drilled hole and worked its way outward and then once it'd reached the end of the disc, it would've started to crack inward. Good thing u spotted it. I dont know what happens when discs shatter but I can imagine it wouldnt be nice...
-D
-D
Thats the reason why I don't like crossed drill seen "cracking" happen a bit but was only with the 4000 series..but thats only what I have seen..
But I like slotted works for me and when there are no slots anymore you know its time for new rotors :) I am really hard on brakes as well so my rotors have done well to put up with me from general driving and about 10 trackdays/supersprints :)
Have any of you SA peeps heard about "Superlap"??
http://superlap.com.au/
Was a bit disappointed to not see any SA workshops on the entry list :) Would think that there would be some really good workshop cars/ individual owner cars to represent SA floating around :)
It's the first time a "timeattack" event to happen in Oz and we are following in the Japs footsteps ..Going to be off tap to see so many Oz cars coming out to battle for the fastest cars in Oz!
slotted is all you need for gas evacuation.....don't touch X-drilled even from factory!
Yours are dimpled Mark which is fine but still not necessary imo.
some are actually ok pete. but im talking about the uber expensive discs that have the holes added while the metal is still red hot and annealing.... metal gets most of its bonded durability during the cooldown, so as long as the holes are done during the construction, its generally a lot safer. Also most professional brands dont actually put the holes in on the outer edge of the rotor, only on the inside and middle (being that a disc rotates a lot faster on the outside and thats where all the brake stresses are). Think of Samurai Swords as a point in case. The swordsmiths will coat the back end of the sword in clay while its still red hot and then they'll cool the blade with water. The blade edge stays hard cause its cooled quicker which is good for sharpness, however its very brittle. The back side of the blade is soft and flexible and can withstand the shock of the saber actually hitting something (or being hit). Without the annealing no samurai sword would be able to withstand even a flesh contact without being damaged. Folding was only ever done because of the exceptionally low quality steel in Japan, they had to do it...
Tho I do agree with you... Braking effects are like trying to rip the brake disc in 2 pieces, the side leaving the pad and the side entering the pad.. having a drilled hole is just asking for trouble, and considering most of us are just doing daily driving/occasional track then you'd be bonkers to stick cross drilled rotors on and then go track em ;P The DBA's have failed for a lot of people and theres an entire thread dedicated to them. RDA for my money, perhaps the dimpling is overkill but I wouldn't say no to the extra speed reduction (esp since I don't track the car).
-D
Sean/Boostworx runs in the improved production with a little 808 I believe it is.
In his old rx7 I believe his best time around mallala was a low 1min 17?
Does he!!..I know a few cars in improved production over here in NSW
I am not up with good times around Malalla, but I seen Munro did a 1:19 in his beast so a 1:17 from a Old RX7 cant be half bad :)
Andrew (Blue32) did 1:17 when he did his run at mallala. 2 seconds slower than the lamborghini gallardo :)
-D
Andrew (Blue32) did 1:17 when he did his run at mallala. 2 seconds slower than the lamborghini gallardo :yes:
-D
i seen it with my own 2 peepers... was pretty intense. considering he was on semi slicks past the wear ban( f**ked) and engine temps were like a sunday drive :miner:
-D
Nice..I am itching to see this car in the flesh! Andrew seems pretty cool as into the motor sport pretty heavily! HI5!!
My semis are nearly on wear ban and the A048S become greasy after 5 hard laps not up to 15minute sessions..but makes it interesting
I think he should invest in lap timer and in car camera! :miner:
haha would of like to see the Lambo drivers face with a GTR coming up behind him!! Stalking is fun ! :yes:
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
