Just like to give a plug for the boys down at Adelaide Radial Tyre. Had some suspension work done on my car there today and they were AWESOME! Great price too, the car now handles even better and I can't wipe the smile off my face :D
yeh they are awesome, they've done my clutch, set me up with good rubber and had my weel alignment and suspension checked there a few weeks back... getting all upgraded bushes there soon when i have the cash....... cant remember the name of the younger fella... i know daryl owns the joint but the yonger fela with the goatee is awesome he asked me to hang around in the workshop and pointed out all my perished bushes while the car was up on the hoiste! great customer survice and yes very fair pricing!
for some reason i read that as "i'm going to start dobbing myself in".
i was like, huh?
I'd only have to dob myself in very occasionally. :D
I wouldn't bother if they where only going say 80km/h, but there is one bloke that regularly go through the top of second and half way through third (In a soarer) before backing off. He'd have to be hitting at least 150.
no probs man will ring around 12 or there after
I'm all over the place tomorrow Steve......unfortunately I wont know till about midday.
If midday is not too late to organize anything, ring me then and I'll see if I'm nearby.
who knows of a good mobile dent puller...i have 2 small dents or ding, one on either side of my car...stupid people swinging ther doors into it before i got it..
who knows a good mobile repairer and aprox $?
I would recommend Damien, from Special FX paint
He removed a dent on my car, :) the work was A1, as was the service. :D (he also does work for car yards and crash shops)
Phone him on 0419779192 and tell him Guy sent you.
ay RYAN, i see that sunday is raining...i dont have a shed mate, i hope ya dont mind gettin a little wet? lol :D
should be fine craig, if on sunday morning it looks bad you can come to my house...im more excited about seeing this R31! hehe f*k the timing belt. lol jks
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
