Just like to give a plug for the boys down at Adelaide Radial Tyre. Had some suspension work done on my car there today and they were AWESOME! Great price too, the car now handles even better and I can't wipe the smile off my face :D
yeh they are awesome, they've done my clutch, set me up with good rubber and had my weel alignment and suspension checked there a few weeks back... getting all upgraded bushes there soon when i have the cash....... cant remember the name of the younger fella... i know daryl owns the joint but the yonger fela with the goatee is awesome he asked me to hang around in the workshop and pointed out all my perished bushes while the car was up on the hoiste! great customer survice and yes very fair pricing!
for some reason i read that as "i'm going to start dobbing myself in".
i was like, huh?
I'd only have to dob myself in very occasionally. :D
I wouldn't bother if they where only going say 80km/h, but there is one bloke that regularly go through the top of second and half way through third (In a soarer) before backing off. He'd have to be hitting at least 150.
no probs man will ring around 12 or there after
I'm all over the place tomorrow Steve......unfortunately I wont know till about midday.
If midday is not too late to organize anything, ring me then and I'll see if I'm nearby.
who knows of a good mobile dent puller...i have 2 small dents or ding, one on either side of my car...stupid people swinging ther doors into it before i got it..
who knows a good mobile repairer and aprox $?
I would recommend Damien, from Special FX paint
He removed a dent on my car, :) the work was A1, as was the service. :D (he also does work for car yards and crash shops)
Phone him on 0419779192 and tell him Guy sent you.
ay RYAN, i see that sunday is raining...i dont have a shed mate, i hope ya dont mind gettin a little wet? lol :D
should be fine craig, if on sunday morning it looks bad you can come to my house...im more excited about seeing this R31! hehe f*k the timing belt. lol jks
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
