bord bord bord bord bord bord dmdesljksxdfz,mnbzds/lfgh bord but........................... i brought some new dior last night yay ................................thats all bord bord "sigh as i bang my head"
Just got the car on the dyno, still need to put gtr injectors in and get jeff to remap. Does any1 know if this is ok??
Looks good.. ~7 years ago mine made 164rwkw on 15psi with 12:1 afr's.
Went damn well 0-100 in low 5secs and 0-180ish in high 13's to flat 14's.
thats great
are you coming on the cruise havent seen you in ages
small bearded dragon
large tree
impressive written assignment
large
legs
farting noises
death
arm wrestle
I wrestled a bear once
small ant
rather cute lady
beer
carlton dry fusion
cutie bubby.
booooooogy boooooooogy bum bum
pretty impressive! got a friend who has an r32 as well with a high flowed turbo! pushed out decent power, like over 190kw or so! but it lagged out like crazy, didn't see any power till almost 5000rpm!
thats great
Unfortunately not; the car is laid up in the drive way. Fitting a set of cams tomorrow; replacing the steering rack after work during the week; then in for a tune so I will miss the cruise.
I had a larger turbo on the rb20det for a while; the following week I dropped the stocker back on and crammed 1bar back in to it as the larger turbo was gutless through first and was slower for general street duties than the highflow. Which is when I decided the rb20det was not for me.
so what you decided to build an rb30? must have pretty crazy torque
huh?? Someone correct me if I'm wrong but that fuel map looks like its all over the place.
I'm assuming the bottom graph is AFR's & not boost pressure & therefore should be alot flatter.....anywhere between 11.5 - 12.2 depending on your preference.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
