Anyone wanna sell me an R34 Power FC? I hear alot about modding them to suit your application, so rb26 being modded to suit rb25 neo. Whats the go?
Can't mod the rb26 pfc to suit the Neo as they are a different plug. Could possibly do it I suppose if you grab a 25 or 26 plug and then painstakingly swap each individual pin. :P
NEO engines have variable valve timing, so Im not quite sure that they will fit rb26's... I dont believe there were any rb26's released with VVT... will probably need a special ECU to do VVT.... possibly easier to just remap the stock ecu
-D
-D
Nah its not variable.. Its the same as the r33 but 'apparently' smoother in its transition; of which comes down to the solenoid mechanism its self.
You can use a simple $34 window rpm switch imported from the US from a mob that I know of. Its basically a NOS switch; switch on at x rpm then switch off at y rpm.
yea thats what i was gonna say lol
people usually use rpm switch when they use an rb20 remapped ecu on an rb25.
hrm news to me, i always thought they were some special type of comp controlled head ...
will know better next time :P
-D
On a totally unrelated topic, theres a"1993 GTR turbo skyline" in the paper for $10,000. im thinking its not a gtr, so i messaged him "hey mate, is the gtr still for sale?" i get back "yes". hmm, guess ur keen to sell then
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
