Anyone wanna sell me an R34 Power FC? I hear alot about modding them to suit your application, so rb26 being modded to suit rb25 neo. Whats the go?
Can't mod the rb26 pfc to suit the Neo as they are a different plug. Could possibly do it I suppose if you grab a 25 or 26 plug and then painstakingly swap each individual pin. :P
NEO engines have variable valve timing, so Im not quite sure that they will fit rb26's... I dont believe there were any rb26's released with VVT... will probably need a special ECU to do VVT.... possibly easier to just remap the stock ecu
-D
-D
Nah its not variable.. Its the same as the r33 but 'apparently' smoother in its transition; of which comes down to the solenoid mechanism its self.
You can use a simple $34 window rpm switch imported from the US from a mob that I know of. Its basically a NOS switch; switch on at x rpm then switch off at y rpm.
yea thats what i was gonna say lol
people usually use rpm switch when they use an rb20 remapped ecu on an rb25.
hrm news to me, i always thought they were some special type of comp controlled head ...
will know better next time :P
-D
On a totally unrelated topic, theres a"1993 GTR turbo skyline" in the paper for $10,000. im thinking its not a gtr, so i messaged him "hey mate, is the gtr still for sale?" i get back "yes". hmm, guess ur keen to sell then
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
