thanks for the input guys. and thanks guy i might take you up on that. ill call you if need be.
thanks for your input cubes!
comp has 4 gig ram, core 2 extreme(quad core), 768 3d card(overkill) and most games i can crank up.. a few stall but with grid it glitches and freezes up like crazy. running 1920x1200 res... hoping xp will fix this issue and just not happy with vista on the whole.
I have alot of mates who use vista and haven't heard of the issue's your describing i would almost put it down to being a dell
just because they claimed it was the fastest ns whatever if they used inferior parts for memory or graphics card your going to end up with alot of problems
i also know nvidia aren't that great with there drivers so it may be a case of searching if other people are experienceing the same problems with dell systems or the same graphics drivers
just as an example with the game grid i was having corrupted gfx on the demo so i rolled my drivers back and was all good now i have the full version and even newer driver haven't seen that problem since
*cough* Nvidia drivers are probably the most solid drivers out there on the market. If you're using beta/alpha drivers then you're bound to have issues, but historically Nvidia have had much better drivers than ATI. That said, I've owned ATI and Nvidia and both have had isolated incidents with driver releases from time to time...
-D
3d card is nvidia 768 x 16 8800 ultra. how would i update drivers?
will try that before i whipe it.
www.nvidia.com
go to download drivers
enter 8800 ultra as the gfx type. download the release that suits your operating system (vista)
Once downloaded, Run it. Voila, new driver installed.
-D
hmmm moving house sucks.
me and the missus are putting our unit up for rent, after spending mega bucks on a re-furb.
it went into the paper on sat, and the net >click here<
we have 3 couples coming through it tonight for an inspection!
one couple has offered more then the weekly rent, they want it so bad!
but the real estate agend doesnt like the look of them lol.
its all good though saving more money FTW
moving back with missus mum FTL
having a double garage all to myself FTW
real estate agent fees, FTL
I'm in the talks at the moment with the bank ... looking at bidding on a massive 4 bedroom home (with 2 double garages) on a huge block of land :(
If I get that house, I'm def throwing a house warming party!!!!!
*fingers crossed*
Well for what its worth my specs..
All using the latest drivers from the respective websites.
Gigabyte EP35-DS3
Gigabyte 8600GT @ 1680x1050
All rock solid memtest (test 5 and 8 for 24hrs) and prime stable.
Runs Grid fine no hang ups or stutters.
I had a slight issue when I was running a 400fsb where it was rock solid in prime and memtest yet BF2 would still randomly drop to the desktop. Dropped it back to 333 with the same overclok and its now fine.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
