thanks for the input guys. and thanks guy i might take you up on that. ill call you if need be.
thanks for your input cubes!
comp has 4 gig ram, core 2 extreme(quad core), 768 3d card(overkill) and most games i can crank up.. a few stall but with grid it glitches and freezes up like crazy. running 1920x1200 res... hoping xp will fix this issue and just not happy with vista on the whole.
I have alot of mates who use vista and haven't heard of the issue's your describing i would almost put it down to being a dell
just because they claimed it was the fastest ns whatever if they used inferior parts for memory or graphics card your going to end up with alot of problems
i also know nvidia aren't that great with there drivers so it may be a case of searching if other people are experienceing the same problems with dell systems or the same graphics drivers
just as an example with the game grid i was having corrupted gfx on the demo so i rolled my drivers back and was all good now i have the full version and even newer driver haven't seen that problem since
*cough* Nvidia drivers are probably the most solid drivers out there on the market. If you're using beta/alpha drivers then you're bound to have issues, but historically Nvidia have had much better drivers than ATI. That said, I've owned ATI and Nvidia and both have had isolated incidents with driver releases from time to time...
-D
3d card is nvidia 768 x 16 8800 ultra. how would i update drivers?
will try that before i whipe it.
www.nvidia.com
go to download drivers
enter 8800 ultra as the gfx type. download the release that suits your operating system (vista)
Once downloaded, Run it. Voila, new driver installed.
-D
hmmm moving house sucks.
me and the missus are putting our unit up for rent, after spending mega bucks on a re-furb.
it went into the paper on sat, and the net >click here<
we have 3 couples coming through it tonight for an inspection!
one couple has offered more then the weekly rent, they want it so bad!
but the real estate agend doesnt like the look of them lol.
its all good though saving more money FTW
moving back with missus mum FTL
having a double garage all to myself FTW
real estate agent fees, FTL
I'm in the talks at the moment with the bank ... looking at bidding on a massive 4 bedroom home (with 2 double garages) on a huge block of land :(
If I get that house, I'm def throwing a house warming party!!!!!
*fingers crossed*
Well for what its worth my specs..
All using the latest drivers from the respective websites.
Gigabyte EP35-DS3
Gigabyte 8600GT @ 1680x1050
All rock solid memtest (test 5 and 8 for 24hrs) and prime stable.
Runs Grid fine no hang ups or stutters.
I had a slight issue when I was running a 400fsb where it was rock solid in prime and memtest yet BF2 would still randomly drop to the desktop. Dropped it back to 333 with the same overclok and its now fine.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
