sorry to hear Min
Amanda has he taken the top off the brake fluid reservoir that will help release pressure
i'm not sure, i'll have to ask him when he wakes up
You have to squeeze the caliper pistons back into the caliper either using a proper tool, a G clamp or two screw drivers....
MIN, a baffle plate between the cat flanges will do the trick.
he tried the G clamp, it ended up getting bent (was pretty old though) so i had to buy him a new 1
but yeah my brother is gonna help him 2moro morning so hopefully they get it
On a sad note, i wont be attending Kellie's cruise :D Dont really feel like driving the car with a defect sticker on it.... i might tag along in someones car
Dont be soft, if your allowed to drive it, drive it
true how long did they give your 24hrs or 48 hrs
Mark are you blowing off the cruise for that gig or you were only kidding
EDIT
that was quick craig did you find anything out about that clutch you were telling me about
^ yeah, extreme heavy duty 5 puck cushion ceramic $320....
im going to hold off on it though, it seems to be going ok (as long as i dont drop it)
i need to focus on window tint/lowering/polish first for A.S.
Rim Question - if you had the choice between 18x8" +38 Model 5 copies, 18x8" +36 5 Spoke Rims, or 17x8" +42 buddy Club P1's in titanium silver - what would you choose? Each are within reach of my price range so really not sure...... I'd like 18's but the P1s are just so appealing...
What I think the P1s would look like:
What the 18" 5 spokes look like
Or AVS Model 5 copies (these are 17's, I would be looking at 18's)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
