how you feeling today Luke,
wanna come on that cruise if you can get a lift to the meeting point you can come in my car still
ah well off to everlast mufflers to fit the other rear turbo brake line and my awd shaft
Still feeling quite under the weather Steve, would love to come but don't think I'd like to risk out being out that long the way that I feel. Thanks for the offer though! Hopefully once all this Regency bullshit is aside, I can FINALLY get my turbos, whack them on and go on an ohhh so sweet cruise with you all :D
what for? you have a handbrake dont you :bunny:
hahaha yes i do!
wouldn't you need R33 callipers too
oh and i have rotors
i dont know wat i need?? i need a full r33 front brake setup yeh?
adrian, When you change your brakes, ill buy your brakes off you for the 31.
keep that in mind!!!
done ryan! there all yours!
Trying to get Adrian's standard struts in but i cant seem to get the front ones in since the hub does not move down any further!! Adrian has already suggested i use spring
compressors to compress the spring --> fit it then loosen it. Would this work and who has one!!!
Cheers
-Min
good cruise!! AGAIN..
had a visit from 6coppers at the last meet point but kel talked her way through it and they were fine! asked a few Q's checked rego.. all sweet...
cruises like this are starting to give SAU a better name with the police!
well done again kel now weres the pics!!
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
