^^ i would to.
but its good that they didnt go to far with things.
shows, if we do the right thing (behave) the police will start to realise that we are not the ''typical'' ''hoon'' import drivers
meh, im just a whore, never mind me
Edited by craig R33
its true craig and as kellie said i think..
we are an australian wide clud cruising all the time! we keep it sensible and if anyone messes up they will be reported...
and hence y kellie gives her name out as the organiser over the cruise! to show them we are dead set about keeping it safe and under control!
wow i think this is one of my few quality posts! hahaha
Know how you feel there Craig (sick as a dog part!) Good to hear you had a great cruise everyone, glad I didn't make it now, if I didn't get defected last weekend I sure as shit would have tonight :bunny:
Night all :P
Yeah, i was down arndale way. There was a holdup of some sort at the chemist down arndale and were millions of cop cars. Got pulled over by Hanson rd
by 2 old dudes in a police Toyota Landcruiser. Got done for spacers on the rear. Not happy about it since all i was doing was driving but yeah ..... Anyone
have a stock R32 steering wheel lying around??
Hanson Road is one of those areas thats generally swarming with cops anyway (and the areas around it). Our training centre is on Grand Junction Road (shares the same facility as the MFS training centre)....and when i used to drive the 31 to trade school id CONSTANTLY get followed (even in its more stocker form that it was over the years. Would usually get pulled over and asked why i was so far from home LOL
if ya have any trouble finding parts let me know, ive got some random stuff laying around that may help ya
yeh steve 4 more road traffic coppers came.. spoke to dan and jenkies and kel and searched cars!
was interesting!!
copper says "whos family car" hahaha
I'm so glad they didnt wanna check out the family car!! LOL
Pulled this yesterday, not bad for my lack of mods, running about 9psi i think.
Sounds about right. Little more boost will pick up 20-30rwkw but its the mid range that is worth while. Accelerates you to that peak power considerably quicker.
Bugger injectors and tune the sucker on E85 for 240rwkw on the std turbo. :D
Nothing wrong with E85. I'll be grabbing myself some larger injectors and retuning.
Haha yeah i have plenty of plans Cubes :D The dyno i had it on is made for commercial vehicle tuning, and apparently readouts are always a little bit less then everywhere else. Should be getting my power fc soon, so ill have the AFR tuned a bit better. Might look at injectors too.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
