Happy Birthday Carl
Damo you want side feed injectors
Damo has a 34 so he will need top feed high impedence injectors i think. Cant remeber whether they are high or low impedence injectors needed.
Well it depends on how much power your after
there is a calculator that you can put in how much power you want to make and it will tell you what size injectors you will need, it will also tell you what power different inj. Will make
So would i be aiming for 550cc or thereabouts for my setup?
440's are good for ~260rwkw and can be squeezed to around 290-300rwkw with some additional fuel pressure.
550's are usually good for a 'little' over 300rwkw before they require more fuel.
If it were myself... Go a set of large sard twin spray 800's they atomise fuel well and then you have the option to tune on E85 and pull an additional 30rwkw out of it and pay less for fuel. :D
Damo i bought mine from Deatschwerks (spelling) in America great pricing and they have a pretty good rep on here.
I have 550cc yuo can buy them off me if you want for the price i paid for them as i think i might go larger.
Bolt straight in with no issues and they have been flow matched from there factory in the US.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
