my bro in law runs red stuff up front and green stuff at the back on his pug 205 gti track car.... never been in a car that can pull up harder.
only problem is they dont really work at low temps, so dont expect them to clamp like all fk a couple blocks from home, can be a bit scary when they are cold
i wouldnt get bendix
im not 100% sure if ill get red stuff it all depends on money QFM are a good price and better than bendix
I've ran bendix ultimates. They were damn good street pads dusty as all buggery slightly hard when cold but not really noticeable. I was luckly they only squeeled only 'just' before coming to a stop.
A mate at work tracks his Pug 205. He has moved from the green stuff to the red stuff.
He was saying the green's are crap at the track on the heavier skylines but damn good on the street but expensive for a street pad.
Red's feel like your pressing on a brake pedal with no booster until they warm up but on the track he said they are unbelievable. :banana:
Another to consider is the Lucas TRW pads. $50-$70 a pair.
http://www.nissansilvia.com/forums/index.p...howtopic=295992
They will be my next pads. :D
yeah my bro in law was finding the rear end would lock up too easy with reds on the rear of his 205... was funny, would just swap ends n spin under hard braking at speed :D
thanks pete, i am leaning toword the greenstuff for the fronts, and bendix ultimates for the rear, does mixing matter?
changing your brake bias can be a problem so unless you know your compounds pretty well I wouldn't like to experiment....you never want your back brakes to take over on a bend.
steve, i was thinkin QFM all round at one stage.
I was looking at the QFM A1RM's but they are a bit too dusty for my liking (bendix Ultimates are apparently worse though) and they don't make them for a Brembo caliper. I'm in the same boat with EBC Greenstuff.....not made for Brembo caliper, hence why the Redstuff which is actually a Kevlar pad with Ceramic particles. Having said that, if you want QFM's for Brembos, you can send your backing plates interstate and be without your car for awhile, they can rebond them for you with any compound that you like.
Most good pads wont be at their best from home to the local deli but the redstuff doesn't need to glow before they bite......just warm.
Your bro in law has affected the brake bias of his car, not recommended. His rears may bite too hard in the cold.....see below for front/rear combinations: EDIT: They would obviously be fine when hot because the fronts would then bite harder.
On Front.............OK to fit or have on rear
Original........................Ultimax only
Ultimax........................Ultimax or original
Greenstuff....................Greenstuff, Ultimax or Redstuff or original
Redstuff.......................Redstuff or Original
Yellowstuff....................Yellowstuff,Green,Red,Ultimax or original
yeah, this happened after a brake upgrade to some slotted cross drilled items. It now has adjustable bias cos that was cheaper than new rotors etc
my car needs a service bad, checked engine oil the other day and was black as. Need to get to the hoist soon.
Same here. I reckon I'm close to the 5,000km service interval. Better get it done before my interstate trip. :laugh:
Hey guys, could anyone lend me their reo bar! Im kinda getting desperate as i plan to regency it tomorrow morning! I dont have much monies to offer but im sure we can figure
something out. (Oh it should only be for a day also since im heading to regency tomorrow morning.)
Regards
-Min
Well a bit of catching up to do for me.
- f**k, i missed wipeout :down:
- scott, fluoro for parklife? fluoro is business as usual for me :)
and +11ty for Ric from Auto Perfection, had my new alarm fitted today, excellent service and awesome product. Highly recommended.
I've driven with and without and didn't like the short shifter. Unsure if it was the box but I found I crunched slightly on hard shifts.
I then grabbed a nismo gearknob with the std rb20 shifter/box. The height of the shifter was just nice.
Then in went the rb25det gearbox which resulted in a taller shifter.
Miss my rb20det gearbox; the rb20det gearbox's feel a hell of a lot nicer to shift for some reason. Every 25t box I've felt in comparison feels big and clunky.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
