so you'll be needing some SAU stickers Matty? :D
yes, i am actually goin to get some hehehehe
nice matty not really old but not ghey like the new ones
yeah, its a series 2 so looks a bit better, has the cornering lamps etc. not a fan of the factory alloys but they're growing on me
MIN, yea Boost solinoid was a two stage bleeder which switched from 5psi to 7psi at 4000rpm on RB25DET!!! The Guy is obviously confused..One of robert's 33's didn't pass tier 3 because of this exact reason. The hose from the compressor housing to the actuator is stock so no stress mate.
Well that explains it all. I feel like sending them a letter with the above information included JUST so other people do not have to put up with their confusion + lack
of knowledge.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
