Just spent 5 hrs taking my old shitty bubbled and screw-hole riddled dashboard out and putting in a replacement. Got the new dash on but need to get some interior parts before I finish the job ;P Heres what the car looked like without a dash
Anyone know what wreckers are open tomorrow?
-D
Wow that's a damned mess :) Not sure about wreckers opened tomorrow, I think you'll be very limited
Hey heslo, was it you or nightcrawler who replaced the stock GTR boost gauge with a psi/bar one in the centre din ? Im sick of mmHg and I want something that goes up to 2 bar or 28 psi... anyone know how I can do this on a 32 while keeping the stock volt/water temp gauges?
Cheers :P
-D
Not me buddy but been wanting to do the same also, don't need the small boost gauge there, wanted to replace it with another gauge but can't find one small enough. I don't know if Andrew did this either but if he did would be interested to see it done
damn, i know someone did it... using the stock triple cluster, and just replaced the faceplate or the gauge mechanics itself... would be nice to get that stock gauge reading up to 2 bar, or even 1.5 bar.... would save my having to sacrifice an aftermarket gauge slot...
Just went for a testdrive, no speedo ;| Think I havent put the speedo cable into the dash properly... ohwell, tomorrow more stuff to do it looks like..
-D
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
