ouch.....lucky you didnt knock yourself out mate
With the number of times I have had these diffs out of cars my biggest fear was that it would drop it on my head and now it has happened. Luckily I wasn't using the pit so it only fell 30cm before hitting me not 1m like if I was in the pit. This is the first time that I had someone "lending a hand" and i think they pulled it off the sway bar which is why it dropped. so I think for now on I'll stick with doing it by my self
Edited by D_Stirls
dont need to replace the plugs unless the old ones are shagged. if still in good nick just clean the magnet and plug.
thanks to damo and chad about the jobi congrats. means alot! im scared as hell, start tomorrow working for a company called maison design as an all rounder.... called up friday, interview saturday, trial monday!! haha awesome!
http://maisondesign.com.au/
lol @ dohmar's lack of dash! looks hectic!
chad! we want pics!! ;) havin fun getting intimate with your cluster?
here ya go buddy, took just under 30 minutes :(
^^^ if they are on pillar and restricting vision they are a no go. but as far as i know guages are allowed anywhere aslong as they dont restrict any vision out the car.. hence why chad would have passed through regency
hmm Nissan got smart when they made my car :(
so i have a "fibre creations" nismo front bar that has no holes. I can get it paitned cheap, but i need to get it fitted, holes drilled and work done, then it gets painted and then i can fit it after painting. Do you think places like all type crash would bother with a small job like that? Any recommendations?
im pretty sure they would, money is money, probably do a cashy for ya
UNfkingBELIEVEABLE
SO I killed the cressida right, drove over 10kays with the needle on H, had the rattle of death going the whole time and also managed to cook the oil in it.
I topped up the oil/coolant today, turned the key and after a few lazy chugs, she fires up and settles to a reasonably good idle, given the previous abuse. I also drove it a further few kays with not a single problem (it hesitated slightly when moving off from a standstill on a steep hill).
I just can't fathom how it could take so much abuse and still run and drive like nothing happened. Fking 7M is damn near unbrakeable :(
When I first bought the R32 going on 8years ago the coolant temp sensor was dicky.. First summer engine temp went from 1/4 to half. I was wondering why the car would get really sluggy and on occasions stall and then not start until it would cool. Water would constantly blow out of the overflow.
Summer past; replaced the coolant temp sensor to realise it was constantly driving around on H. Maxed out the gauge. :S
It went on to clock another 100,000km's. ;)
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
