Aww happy driving that's a longggggggggggggg trip! Hope your not doing it by yourself?
Nah. Got the missus doing some of the driving also. :rofl:
also got loads of DVDs to watch on the way there, so will be entertained nonetheless.
good work Luke shall we go wash our cars before villies :D:(
zip lock bag Joel then you can play with it too ;)
It is the 1991 Winning GTR.
I made one mistake... I couldn't handle it sitting in the box so I removed it and shoved it in a plastic box to look at every day lol.
working good so far cheers heaps man - i will know how much better economy when i fill right up tomorrow
hey steve hows the afm going?
good looking trailer matty is that like phase one and when you get some more reddies make up a frame and put a skin on it
for those going to Blanche town i lived there for about 6-8 months when i was 18 :D boy never done so much drinking in my life - i worked in the Pub and in the bottle recyclers :D
Pete - got your pads today :D:thumbsup:
Awesome trailer matty!! :thumbsup:
We will be building one soon..Have you got specs on it in another thread?
Nah, no specs anywhere else jess, but can find out what design my mate built it from.
Basic specs i know off the top of my head (as its been built to suit my 31)
Deck (being usable area)
Length: 4.5m
Width: 2m (suits 1.8m track of my 31)
Ramps: 3m long, weight ~50kg each (mainly due to the 4mm thick mesh we used)
Axles: 2x 1.4t 45mm square axles with 10" electric brakes mounted on 6 leaf roller rocker suspension ("spring under" configuration.....could have done "spring over" but would have raised the overall trailer height by 4")
Trailer is unoficially rated at 2.8T (purely on max axle rating), but after shepparton we're getting it all looked at and the thumbs up given.
Loving that trailer.
Whats the chances of you knocking me up a nice one for a motorbike?
If you're keen for a motorbike trailer, i'll give ya my mate's number via PM and you can discuss the exact needs with him (he measured up my car to specifically build this for me, but handily suits most nissans..............wont fit a hachi or anything smaller though)
And some more piccies..............with the car loaded on
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
