OK boys, the N1 Water Pumps have arrived........with a spare if anyone wants one (had to order 5 to get the good price).
1x Luke (ENR34).........PAID
1x Luke (Heslo)
1x Ben (Dohmar)
1x Pete (SLED)...........PAID
Very quick delivery........didn't expect them till next week!
I spoke to Martin Donnon when i went to willall today and im getting my car tuned tomorrow arvo.
The reason i went there was im very interested to see what sort of attitude and techniques some of the best known tuners have towards the same car. I'm happy with the tune from Jeff but im curious as to whether it can be done better and have different opinions of what the tune is like. Ill keep you all posted with what sort of feedback i get.
sounds good ryan, keep us posted on the out come.
im keen to see if there is greener pastures than my current work shop of choice.
i have the feeling my car is capable of more, with the right attitide and time spent toword the tune.
Finally, got my car back with no canary on the window! SO nice to have it back. As I picked it up from Synergy, turns out the police had a field day there and defect 10 of their cars for sale, most for "offences" like a pod filter which AFAIK is totally legal so long as it's fastened. Bad day for the boys down at Synergy that's for sure :(
I hope they got a good lawyer. Cops sure had better know what the hell theyre doing if theyre going to screw with someones livelihood.
Defected for pods? If it wasnt fastened then yeah they deserve the defect but if not, I'd be lawyering up.
Does synergy sell vehicles freshly imported or vehicles after compliance is performed?
-D
I'm cleaning out my garage and I have a set of R33 hub assemblies for the front (basically everything between the two swing arms), I don't know what they are worth though??
Can some one give me an idea of what I should put on them? (Note this isn't a for sale post)
They were included in the sale when I bought the brakes for a brake upgrade on my 180 so I didn't purchase them separately .
Edited by D_Stirls
Shit someone's quota must be looking pretty flash now.
SAPOL. Revenue > Respect.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
