that mani wont crack ryan... its already been all gusseted etc, good welds, all been ported and cleaned up and it's not a cheap shitty china mani..... it's the good stuff.
But you already knew that. :down:
Should see my new mani.... :D:D:D:D yum yum..... and the screamer out the bonnet.
i personally agree with Craig i liked the drifteks but its not about what i like :down:
what did you clean your rotors with and does it cost much because i should maybe clean mine so i can paint the hats
you got much paint left :D
I just used wax and grease remover, or thinners will do, there was so much oil on the disks, when i was bedding in my pads it looked like my car was on fire :D I still have to paint and fit my rear rotors, but i should have heaps of paint left for you to use :down:
I'd go the 33 personally, RB25's are alot better than the 20's IMO, then again you could go a 32 and chuck in a 25 motor
The 33's are damn close to the price of a 32 these days..
33ftw.. better motor better gearbox to start off with. Much better modding platform that won't hurt your wallet as much.
I've also heard that I should go for a non-Turbo first, especially since I'm driving an auto atm. Seems like a wise move IMO.
The 15k includes stamp duty, rego and insurance for a year (so about 12 or 13k for the car itself).
Edited by normangerman
12k ono for my 32 with an auto
or its going into smooth garage on tuesday to get a manual converstion with HD clutch and ill let it go for 13k-13.5kono
if you keen check my forsale thread!
http://www.skylinesaustralia.com/forums/R3...y2-t226674.html
Edited by Import S13
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
