Just a quick question, I spose many of you guys feel the same, but I'm selling my AWD Auto Subaru Liberty and want to get a Skyline. Dads not letting me get a turbo and I have persisted but only got yelled at some more.
His excuse is 'you never know when the turbo will kick in and throw you sideways'. Thats about it. 'It would be irresponsible of me to let you get a turbo', 'Not at 17 years old' and all that stuff.
Is there any hard facts about this that can be to my advantage? Stock boost does crap all? You can't feel it? etc etc. He'd let me get a non turbo R33 (140kw) but not a turbo R32 (158kw). 'The disk brakes on the R32 explode and they're generally the worst one of them, the R33 is the pick of the bunch'.
Any common problems the non turbo has that the turbo doesn't? This is concerning both R32 and R33 models.
And for anyone saying how I'm going to be irresponsible and all this stuff, I've had this drilled into by my Dad more then enough. When I go driving with my mates I tell them not to speed and don't care if they get ahead of me. They do stupid stuff and I know who's car not to get into. Even complaining to my sister she reckons I'm the most responsible 17 year old she knows. Ask Kahli on here for some backup, she knows how I drive.
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :rofl:
LOL well i came from a vs auto to a stock standard 32 gts-t, yes there is a power dif and i would def reconmend getting manual as i find it alot safer. In the end u aint gunna get sideweays unless u put ur foot down no matter what car u have!
hows is comming on at a certain rev range every single time 'you never know' going sideways is simple DONT clutch kick
common problem with non turbo is lack of power when you need it
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :(
DONT listen to him thats the expensive way around
find a r32 with a rb25de and when ur older slap a 30 bottom and run 250+ rwkw :D lol
lol +1
So the post whores are back in town :rofl: was very quite without you guys :(
ah, so SAU isnt :D'ed from blanchetown thats good to hear :P
Yes, a couple of noticeable absences, CHAD AND JENKIES! Will probably be doing it again soon tho, was awesome fun!
and this talk about RB30 bottom end gets very expensive very quick if you dont do it right the first time which is moderately expensive
oh cool ill drop that water pump off after work sometime this week you name a day i finish most days @ 7pm but tues will finish @ 5:30
I appreciate that steve but this week is really bad. We've had a close friend suicide and I honestly don't know what my movements are going to be this week... ill msg you and work out a time later
-D
4wd yeah its a pain in the arse as there is the plenum issue if you run an rb25det. Typically for a 4wd you can budget an additional 1k over a std rb26dett rebuild. If its the rb25det then you need low mount plenum.
RWD - the additional cost is very minimal and well worth the huge amount of mid range compared to the 25. No reason it should cost more than an additional 300-400 max.
Back when I did mine it worked out cheaper to do a std rb30 freshen up with an rb25 head than it was to grab a rb25det and drop that in.
ur lucky to get a non turbo r 33!
i was only allowed a front wheel drive!!!
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
