Grab some carby clean. They almost always gum up and cause idling issues.
Does the valve AAC valve need removal for cleaning?
If its idling too high there's another valve that may be the cause. IAC valve. The spring can dislodge and cause a constant 1000-1500rpm high idle.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day :blink: )
Yeah mine idles way too high. I'm guessing the AAC valve is the accessible the one near the fuel filter which can be cleaned whereas the IAC is probably the "cold air by-pass solenoid" which is against the sandwich plate under the centre throttle body which requires a plenum removal and which can't be cleaned (approx $220 new).
Also Cubes, have you got the full specs on your Tighe cams ie. IN & EX opening & closing times etc......I might look into them myself.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day tongue.gif )
I do have the cam sheet. All though your requirements will differ as you are blessed with solid followers.
Tighe did reduce the base circle some what however it doesn't appear to have created any problems.
http://www.skylinesaustralia.com/forums/in...t&id=173055
Unsure if a hammering can cause it to dislodge.. Possibly.
Grab a can of start ya bastard and check for vac leaks bfore you go to the trouble of pulling everything off.
If the spring flicks off you can hook it back on and secure it a little better.
The std gasket will most likely break so grab some ACL gasket paper (the hard yellow paper) as its the correct thickness.
how hard is it to un wire gtr injectors with resistor pack??
If you have used a 280zx/R30 style resistor pack its as simple as heading down to the local auto store picking up a Navara 8pin? from memory plug and connecting each pin to each other (bridge) via wires. Then remove the resistor pack and plug in the bridged plug.
Hey guys just a quick question, i have a massive coolant leak at the back of my engine im pretty sure its just the heater hose leaking, any ideas how hard this is to replace??? or any idea's what the leak could be from its right at the back of the enging just infront of the fire wall.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :() and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Anyone know how to untighten the screws on the front of the fuel rail? Or what i can put on there so its easier to get them out? In heaps tight and i need them out to replace the o rings. Start fixing some small problems before i start driving it again in 2 months.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :( ) and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Aren't Cressy's prone to warping head gaskets? My mates Cressy which had a 5M in it blew 2 head gaskets within 6 months :D
Yeah man cressys eat gaskets like they're goin out of fashion :) Its the head torque that is the problem. Mine has been re-torqued and still fked the gasket out (to it's credit, it did complete about 10kays worth of driving on the H with the bottom end rattling away before the head gasket went :))
I reckon I'm just gonna get a Falcon and stop spendin money modding cars for a while. The Falcon seems to be best suited to daily with occaisional towing duties, so I can still get the busted arse 32 out to the track to thrash, Crazy Max styles with munted rear quarter. At least if I hit the tyres on the entry to 1 it doesn't matter because that quarter is already f**ked :laughing-smiley-014:
what suspension matty?
kyb shocks, aurora springs.....7kg front, 5kg rear, standard size (but slotted) aus del front and rear brakes too................nothing special in pads, and they didnt fade or cook
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
