RB26 pump... MEEE!!!!!!!!!!!! im looking at doing major service in the next month or so!
no probz bud, I'll put it aside for you and if I'm not on the bike tomorrow night I'll bring it to Villis......will you be there at 7pm?
Just fix me up when you can, I'm not that desperate for the cash at the moment if you don't have it yet.
Can I have sex with someone to pay my debt? Preferably female/human female. Preferably alive. Preferably under 80. Got any bad debt u wanna swap sleddo my man?
-D
ohhh maaan!! I'm out of black ink and I'm 1/2 way through printing a report.
Anyone have a T0491 Epson cartridge for an RX650 that they can send through the email :down:
no but if u want I can print it out for u and u can pick it up. just got new inks for my bubblejet on tues
-D
yeah, i'll be there and will probably have the money.
anyonw looking at doing an N1 oil pump group buy, or nismo timing belt?? =P
try Joelo for gates timing belts but I wouldn't waste your money on an N1 oil pump
funny thing, of the 2 or 3 mechanics i've mentioned the 100k service to all have said to not worry about the N1 water pump, but to get the N1 oil pump... maybe its just an R32 thing... =D
was going to just get sock timing belt, but BANNED sugested that for a few extra $$ the nismo one is probably a better buy.
yeah at the end of the day you don't really need either pump but for the same reason you're going for a better Belt (ie. few $$ more) you are better off with the N1 waterpump.
On the other hand the N1 oil pump costs an extra 3 arms & 4 legs, lol........and with the overhead oiling issues that RB's are renown for, why would you want to exacerbate the problem.
Maybe your mechanics are not very familiar with RB engines?
EDIT:
Gates or Nismo are in the same league.....both have kevlar in them. Also, waterpumps will give up the ghost under normal circumstances way before oil pumps.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
