RB26 pump... MEEE!!!!!!!!!!!! im looking at doing major service in the next month or so!
no probz bud, I'll put it aside for you and if I'm not on the bike tomorrow night I'll bring it to Villis......will you be there at 7pm?
Just fix me up when you can, I'm not that desperate for the cash at the moment if you don't have it yet.
Can I have sex with someone to pay my debt? Preferably female/human female. Preferably alive. Preferably under 80. Got any bad debt u wanna swap sleddo my man?
-D
ohhh maaan!! I'm out of black ink and I'm 1/2 way through printing a report.
Anyone have a T0491 Epson cartridge for an RX650 that they can send through the email :down:
no but if u want I can print it out for u and u can pick it up. just got new inks for my bubblejet on tues
-D
yeah, i'll be there and will probably have the money.
anyonw looking at doing an N1 oil pump group buy, or nismo timing belt?? =P
try Joelo for gates timing belts but I wouldn't waste your money on an N1 oil pump
funny thing, of the 2 or 3 mechanics i've mentioned the 100k service to all have said to not worry about the N1 water pump, but to get the N1 oil pump... maybe its just an R32 thing... =D
was going to just get sock timing belt, but BANNED sugested that for a few extra $$ the nismo one is probably a better buy.
yeah at the end of the day you don't really need either pump but for the same reason you're going for a better Belt (ie. few $$ more) you are better off with the N1 waterpump.
On the other hand the N1 oil pump costs an extra 3 arms & 4 legs, lol........and with the overhead oiling issues that RB's are renown for, why would you want to exacerbate the problem.
Maybe your mechanics are not very familiar with RB engines?
EDIT:
Gates or Nismo are in the same league.....both have kevlar in them. Also, waterpumps will give up the ghost under normal circumstances way before oil pumps.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
